Smile Design Treatment is a unique dental treatment which is specially recommended for those who suffer from various oral problems like tooth decaying, tooth loosening, bacterial plaque, weak gums etc. People often lose confidence and peace of mind because of these sufferings. So smile design is the best treatment which enhances your confidence and helps you lead a problem free life. The treatment procedure involves the following steps such as tooth whitening and porcelain veneers. During the procedure the expert dentist whitens your tooth, covers the gap between your teeth, restores broken or discolored tooth and improve the appearance of your smile.
How the treatment procedures are performed?
Smile Design Treatment is a cosmetic treatment that focuses on improving the appearance of your smile through certain procedures such as dental veneers, composite bonding, teeth whitening and tooth implant. Some factors taken into consideration for this treatment include facial appearance and skin tone, gum tissues and lips. The treatment not only focuses on your teeth, but also makes your lips and cheek look good so that you get a perfect makeover look; Tooth proportion and smile line- in order to make your smile look flawless, the orthodontist or cosmetic surgeon would examine if your teeth are in correct proportion, or the imaginary smile line following the edges of your upper lips is in proportion with the curve of your lower lips.
Why choose us?
SAI Laser Dental Care is the leading clinic which offers Smile Design Treatment and maintains your smile make over in an affordable range. With years of experience this clinic is pioneer in this service and offers a flawless dental structure in a professional way. All the dentist of this clinic are well experienced to perform the best service and help the clients to reshape their teeth or restore the original color of your teeth. With long history and innovation this clinic brings advance infrastructure and equipment to advance Smile Design Treatment and make the clients satisfy with their needs.
