Dental X-rays is the best part of your dental treatment which provides the images of your teeth that your dentist uses to evaluate your oral health. These X-rays are used with low levels of radiation to capture images of the interior of your teeth and gums. This can help your dentist to identify problems, like cavities, tooth decay, and impacted teeth. If your dentist is tracking the progress of a dental problem, they may recommend dental x ray to identify the problem and provide you the best solution of your problem. This dental x-ray is a type of energy that passes through soft tissues and is absorbed by dense tissue. X-rays are divided into two main categories, intraoral and extra oral. Intraoral is an X-ray that is taken inside the mouth. An extra oral X-ray is taken outside of the mouth. Radiographs allow dentists to see inside a tooth and beneath the gums to assess the health of the bone and supporting tissues that hold teeth in place. There are a number of X-rays a dental professional can order. The type of X-ray needed will depend greatly on the type of care the patient needs to receive.
Different types of Dental X ray:
- Bitewing. This technique is commonly used to check for cavities between teeth.
- Occlusal. This X-ray is done to detect anatomical abnormalities with the floor of the mouth or the palate.
- Panoramic. This X-ray is used to check your wisdom teeth, plan for implanted dental devices, or investigate jaw problems.
- Periapical. This technique focuses on two complete teeth from root to crown.
Why choose us?
SAI Laser Dental Care is the leading clinic which offers high standard Dental x ray service and helps the clients to get rid of different type of dental problem in complete way. Dental x ray is the best process which helps the dentist to diagnose common problems, such as cavities, gum disease and some types of infections. Over years of experience this clinic is well endowed with latest techniques and advance infrastructure under one roof to perform the advance dental x ray service and provide the best service to its clients according their oral health needs. All the radiographers of this clinic are expert to do the process in a professional manner and offer the authentic report of your dental problem and help you to get rid of any serious dental issue from primary level.
